Error Codes
I have a 97 T&C van and my Service engine light soon came on. I noticed right after that my trans wouldn't shift through all of the gear ranges. I stopped and checked the fluid and it was low so I filled it and it was fine after that. Would low fluid bring up a 700,732,1782, and 1789 code? All of these are trans specific or could there be another problem?
Re: Error Codes
Re: Error Codes
All these codes do appear to be trans related. Did you clear the codes? Clear the codes, and see if they reappear now.
Re: Error Codes
Ditto to jsinton. You can disconnect the battery or a better idea would be to go to Autozone and ask them to reset them using a scanner. It's free. Yes, lack of fluid can cause these codes. Fluid level is critical. Keep it full.
Here's a website I use when I can't find a code on the published lists: http://www.iequus.com/support/obd2_definitions.php
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
