Old 03-19-2007, 06:02 PM
murphys223 murphys223 is offline
Send a message via MSN to murphys223 Send a message via Yahoo to murphys223
Unhappy 99 taurus wagon power door lock problems
i just baught a 99 taurus wagon and the driver's side front and driver's side rear passanger door and rear hatch lock does not work however the two passanger side door locks does work any ideas on what the problem could be?
if its any help it does have a remote lock/unlock on the keychain....
thanks....
Old 03-19-2007, 10:35 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 99 taurus wagon power door lock problems
All the door locks share common lock and unlock wires. Well, with the exception of the driver's door for the priority door unlock, but when not active, the relay ties it to being common with the other locks motors.
If three of the 5 are not working, you might have three bad motors or bad wiring to those three.
Any way you can find out if they all stopped working at the same time or if they went out at different times?
-Rod
Old 03-20-2007, 02:45 PM
GPFred GPFred is offline
I recently had this problem with my 98 Taurus. I was told that I would have to replace the lock cylinders. NOT!! They are probably just locked up with crud. This is what I did. I first blew in some liquid wrench using the straw attachment and kept working at it with the key until it broke loose(the lock, not the key ) Then I took electrical contact cleaner and cleaned it out real good. Then after I let the cleaner dry out of the lock, I relubricated the lock with graphite. Not had a problem since. I left the door locks in place, but I ended up having to take the lock out of the trunk deck to break that one loose as it was gunked up with road dust and it didn't matter what I did. Good Luck.
Old 03-20-2007, 10:12 PM
shorod's Avatar
SHO No Mo
You bring up an interesting thought. I made the assumption that the problem was with the power locks, but it could be the mechanical side of the locks. So, murphys223, which is it, mechanical or power locks? The door lock motors don't operate the key cylinders during operation, so if the power locks work, but the key cylinders don't, GPFred is on the right path.
-Rod
Old 03-21-2007, 02:20 PM
-Rod
well the electric part of the lock does not work but the key lock does and the two driver side and rear door stopped at the same time and as i said before the other two doors are still working also it doesnt matter witch lock switch i use i still get the same reaction any new suggestions?
Old 03-24-2007, 05:53 PM
the problem is electric the manual works fine and the doors that do not work all stopped at the same time
Old 03-24-2007, 09:31 PM
shorod's Avatar
SHO No Mo
If you'd like me to send you a copy of the power door lock wiring diagrams for you car, send me a private message with an e-mail address that can accept PDF attachments.
You're probably at a point where you need to get out the multimeter and start making measurements.
-Rod
Old 04-04-2007, 06:13 PM
superiorfil@yahoo. superiorfil@yahoo. is offline
I also have a 99, but its a SE. recently purchased, but does the same thing. I can hear the locks trying to engage but nothing happens? thanks for any help. phil
Old 04-04-2007, 09:53 PM
shorod's Avatar
SHO No Mo
Welcome to the forum!
So, you hear your locks "but nothing happens?" Is that both in lock and unlock, or if you lock the doors manually, will the power locks unlock them? Do you see any movement of the lock knob when you hear the locks trying to work? Do the manual lock levers and key cylinder work freely? Do any of the power locks work?
-Rod
Old 04-05-2007, 06:06 PM
thanks for your interest, only the drivers door seems to open with key. Trunk, passenger won't budge, buttons move up and down with minimal effort and can hear the two back doors and pass. try to lock when car is put into drive (safety i suppose) it's weird, can the mechanism become gunked up with stuff? danka, phil from souptown USA
