Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-19-2007, 04:47 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Front Brake Pads 89 Caprice Wagon
Any suggestions for front brake pads?
Should I go with:
Semi-Met
Ceramic
Organic
Carbon Met
Which would give the best braking performance for day to day driving without excessive rotor wear.
I do my own brakes so long wear and dust are not a major concern for me.
Also, I have been using stock rotors, would drilled and slotted rotors make a difference.?
Thanks for the input
Al
Old 03-19-2007, 05:33 PM
Blue Bowtie's Avatar
Registered Offender
Re: Front Brake Pads 89 Caprice Wagon
Carbon metallics are excellent for stopping power. They actually work a little better when warm. They do tend to create a lot of dust, however. Rotor wear is not a great problem. Ceramics dust less, but also fade a bit more with heat. Organics would be at the bottom of my shopping list.
Old 03-19-2007, 05:47 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Carbon Metallic, bar none. Nothing I've used works better, or as good, and I've used 'em all!
I will never go back. Blue Bowtie is right, they do create a lot of dust.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-19-2007, 07:07 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Organics are crap. Owned my tempo 5 years, all the auto store here sells for it are organic, about to do my 3rd set. They eat rotors too.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 03-20-2007, 11:47 AM
Blt2Lst's Avatar
Thanks for the suggestions.
I think I will try the carbon mets.
Any suggestions on the rotors?
Drilled & slotted or stock?
Al
Old 03-20-2007, 02:22 PM
silicon212's Avatar
Confoundingly Lucid
Stock. Drilled and slotted will help with heat disbursement in racing situations, but they also decrease available braking surface - the pads don't stop air too well.
Old 03-20-2007, 09:46 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
According to a GM engineer that came to our college a few months ago, the holes in the rotors aren't designed to keep the rotor cool, but are designed to act as a release for the gasses created by the rotor and pad during heavy, high speed braking. Thats also why most, if not all of the pads you buy now a-days have the slit cut down the middle of the pad. The quicker the gasses can escape, the better pad to rotor contact, thus better braking power. But for everyday use, I see drilled rotors as excessive.
Old 03-22-2007, 05:02 PM
Blt2Lst's Avatar
Thanks for the info.
I LOVE THIS PLACE !!
Old 03-25-2007, 09:30 PM
Blt2Lst's Avatar
What is the rule of thumb on resurfacing the rotors.
I replaced my rotors last brake job and do not feel any runout through the pedal about 25k miles later.
Can I get away with scuffing them with 180 emory paper or should i have them turned.
Thanks
Al
Old 03-25-2007, 09:50 PM
silicon212's Avatar
Confoundingly Lucid
Have them turned. Any time I've ever done the scuff job I've wound up with warped rotors. The $8/whatever charge is cheaper than new rotors, especially if you have rear discs like mine which are $70/each.
Old 04-11-2007, 09:07 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
semi metallic ones eat rotors
organics are the softest and messiest and quietist too but dont take heat very well and can fade sometimes
carbon metallic is not the proper name/term
ceramic are the most heat resistant and are the hardest but i dont think youre supposed to use the stock rotors with them, im not sure on that though
i use semi metallic if i have trouble with organic or have nice wheels that i want to keep clean
check rotors for wear down replace before minimum thickness occurs
the min. thickness is cast on the rotor where the wheel studs are at on it
if they are gouged from the rivet heads then they are junk time for new ones
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 04-11-2007, 09:20 PM
silicon212's Avatar
Confoundingly Lucid
Carbon metallic is a proper name for a type of pad. They're made by Performance Friction.
Old 08-19-2007, 12:09 PM
Blt2Lst's Avatar
Thumbs up Re: Front Brake Pads 89 Caprice Wagon
I just installed PFC carbon metallic pads, new rotors and both calipers.
Man, what a diffenence those pads make. This land barge (wagon) never stopped so well. I will never go back to regular semi mets or organics. Well worth the extra $.
Thanks again for the input.
Al
