Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-19-2007, 03:02 PM
TURNIP01 TURNIP01 is offline
89 Ciera cranks won't start
Bought a 1989 Olds Cutlass Ciera 2.8l 6cyl two weeks ago from a mech. and it ran very good. It quit on me after a week, but i sprayed starter fluid in the the intake at the air filter area and with a jump it started and ran for two days. but now it cranks but won't start. I charged the battery once, checked the cables and are fine with no corrosion. Receiving voltage from all the charging components, and I am planning on getting the ignition coil tested once i figure out how to remove it with my Haines manual book instructions. the lights and radio work. there is fuel in the injectors and the the tank is half full. i cleaned the throttle with a throttle cleaner the day i sprayed the starter fluid. who knows? should i take anything else in to get tested?
Signed- female who won't give up
Old 03-19-2007, 03:12 PM
Scrapper Scrapper is offline
AF Premium User
Re: 89 Ciera cranks won't start
i'd say yur best bet is what your going to do on coil test because no sark no gas no start.....
could also could also be module but check coil first...
good luck.....
scrapper
Old 03-19-2007, 05:08 PM
thanks. but i have new worries... went under the car to check the starter and solenoid connections and found oil outside of my oil filter area, it ran down from above the oil filter area. could there be a blown head gasket? if there is a blown head gasket would it just crank and not start? i checked the oil dipstick and there is still oil in the engine. Is the head gasket the same as a oil gasket? please help....
Old 03-20-2007, 04:41 PM
AF Premium User
crank posion sensor if it's gone you can keep turning and over and will not start.and gaskets well same put different.. and if head gasket in can start but if theres a bunch aniti or water in cylenders your plug's could be very wet and wont start..good luck.....
Old 03-20-2007, 04:54 PM
AF Premium User
oh and the oil leak by oil filter is your sending unit leaking.. not a big job unscrew it screw it new 1 back in..watch it you just want too get it snug or threads brake off new sending unit.get 1 autzone or advanced these are cheapest places..
oh and good luck again.....
