Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 03-19-2007, 12:42 PM
C2Z06 C2Z06 is offline
Send a message via AIM to C2Z06
Sounds of sloshing water.
Recently my car has sounded like there was a tub of water in it. I've openedt the hood and can't find where any water was. From a stop to start or slow turns, it sounds like water is just slushing aroung inside there. I have no idea where to go with this since I've never encountered it before. Please help.
Old 03-19-2007, 07:52 PM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
Re: Sounds of sloshing water.
Check under the spare tire in the trunk.
Old 03-20-2007, 09:29 AM
It's dry. The sounds comming from under the hood/dash. I hope I don't have to pay a lot of $$$ on this.
Old 03-20-2007, 08:06 PM
240slider's Avatar
240slider 240slider is offline
check and see if your carpet is wet if so the AC drain plug maybe clogged .
Old 03-21-2007, 02:05 PM
Carpets dry. You're the 2nd one to mention the AC drain plug. How do I get to it?
Old 03-31-2007, 07:54 PM
240slider's Avatar
if you look in the engine bay it's just slightly below the battery. it looks like a regular piece of plastic tubing .you have to have access to shop air or compressor to blow out the tubing to remove what ever is clogged with air.so the water can come out .I hope this helps you out
Old 07-30-2007, 05:44 PM
AltimainIowa AltimainIowa is offline
I have a '97 with the same problem. Do you have to take out the battery to get to the drain hose?
Old 08-20-2007, 01:21 PM
I didn't get to drain the hose. It cleared up on its own when it got hot.
