Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 03-19-2007, 07:43 AM
IH-Warranty's Avatar
IH-Warranty IH-Warranty is offline
Send a message via AIM to IH-Warranty
Speedometer quit working
1995 Mercury Mystique
2.5 Liter V6
Build 1/95
I have been having a problem with the speedometer bouncing around & then quit working. After doing some reading on here found it was probably the VSS sensor. Ordered a sensor & went to replace it this weekend & the found this car has a speedometer cable and it is broken just before it goes through the firewall. Went to the local autozone to get one & the guy there couldn't believe it had a cable, but none the less, they didn't have one. My questions are, not only were to get one, by how hard is it to replace the cable.
Is it a one piece cable from the gauge to the VSS or is it a two piece cable?
Old 03-19-2007, 09:39 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Speedometer quit working
Two piece cable. The part # is F5RZ-17260-D.
Post over the contour.org troubleshooting. Someone should be able to help you there.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
