Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-09-2002, 01:02 AM
IVINS812 IVINS812 is offline
moisture in headlights
I have dried out my headlights on my 93 bronco too many times to count, checked the oring on the bulb, and even pressurized the the lens (didn't leak) where is the moisture comming from and how do I fix them???
Old 10-09-2002, 06:32 PM
fordman123 fordman123 is offline
Common problem on Ford's.
The only solution that I have found is replacement.
Fordman
Technical Consultant
Old 03-17-2003, 04:29 PM
daytonaes93 daytonaes93 is offline
Send a message via Yahoo to daytonaes93
im not positive if u can do it on those lenses but if u can try to make a small hole in the botton corner of each lens and if any moiture gets in it should automatically run right out of the holes
Old 10-13-2003, 03:32 AM
autoplaneguy autoplaneguy is offline
fogged plastic headlights
a fix that may work if you can do it yourself, this is familiar to
Mustangers as the 87-93 headlights are similar , try drilling two holes
(1/8 or not much larger hole at the bottom corners of the headlight)
drill this at a slight angle to get it to drain. If it doesn't work or has gone
milky already, get one or both from a aftermarket body shop supply , much cheaper than Ford and almost the same if not the same. Try ebay
for these too---- but first try the drilling holes, it has worked for many.
If you can't find these locally ask a helpful body shop where they get them from, you may be able to do these yourself as they are easy and save a lot.
