Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 03-18-2007, 07:22 PM
rebscoach rebscoach is offline
belt replacement
Can anyone explain how to replace serpentine belt on a 05 Ion, Thanks
Old 03-23-2007, 09:27 PM
ksion15's Avatar
ksion15 ksion15 is offline
Re: belt replacement
i usually do it from under the car, but it is possible to do it from the top. from the bottom, you have to take the right wheel off. then take the wheel liner off. this consists of about 8 pushpins (approx.) a seven mm screw and a ten mm screw that attaches the air intake to the frame. then you'll need something (ratchet or belt tool) with a 3/8 head to relieve the tensioner.
from the top, youl'll have to jack the car up, support the engine under the oil pan, take the air filter housing out, remove the upper mount, then use the 3/8 tool of choice to relieve tension. it's not too hard, but easier with a lift.
K.S.
Service Technician
Saturn of XXXXXX
ASE Certified
GM/Saturn Certified
Old 07-05-2007, 02:58 PM
cubano112266 cubano112266 is offline
Send a message via Yahoo to cubano112266
Smile Re: belt replacement
Does anyone know which is the best belt to use?
Old 07-06-2007, 02:44 PM
rodeo02 rodeo02 is offline
Any of the name brands will do. It's a very simple serpentine belt setup on the 2.2L. The OEM belt should last a very long time.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
