Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-18-2007, 05:39 PM
saturnsc2's Avatar
saturnsc2 saturnsc2 is offline
fog lamps
i have a 2001 sc2. what do i have to do to replace the driver's side fog lamp. it's full of water. do these lamps have to be aimed also?
Old 03-22-2007, 11:49 AM
drew300 drew300 is offline
Re: fog lamps
Why not just pull the fuse for them and be done with it.
I've never seen a factory "fog lamp" do more than light up puddles so close to you that they can't be seen from the drivers seat, and add glare for the on-coming driver. And without them, you may see a mileage increase.
I've never been able to figure out why they seem so popular. People even use them on well lit streets.
Old 03-22-2007, 03:53 PM
samprix samprix is offline
Re: fog lamps
Some states require for inspection that all lights on the vehicle must be working. Even if the lights are of an auxilary nature. I had a truck fail inspection because one visor light was burnt out. If the lights are aimed properly they shouldn't affect on coming drivers. If they are factory lights, then park on a flat surface and use the other fog light as a reference for aiming. People use them because they think the lights look cool
Old 03-23-2007, 10:08 PM
ksion15's Avatar
ksion15 ksion15 is offline
Re: fog lamps
to replace the bulb, you can reach under the front fascia and twist the socket to remove it, then unplug it. reverse order to install. to aim it. park 25 ft. from at a flat wall. adjust the beam so that the top of the beam on the wall is no higher than 4 inches higher than the top of the fog lamp. this is factory spec.
and to add, how the hell are you going to get more mileage with no fog lamps?
K.S.
Service Technician
Saturn of XXXXXX
ASE Certified
GM/Saturn Certified
