Old 03-18-2007, 05:22 PM
tmathew1us's Avatar
tmathew1us tmathew1us is offline
help with fixing glass after paint leaked on it
I did a really poor masking job and now have a problem. The masking tape got wet and lost adhesion, and now I am left with this (below).
I was using rattle can black paint. How do I remove this?
I have tamiya rubbing compound and 400-12000 grit paper at my disposal. I have read that one can sand this away, but I am a little nervous about ruining the shine on the glass. Any suggestions?
BTW, the model is a Lindberg Chrysler Atlantic.
Thanks in advance!!
[http://images21.fotki.com/v631/free/...pg?1174256010]
[http://images22.fotki.com/v753/free/...pg?1174256029]
[http://images22.fotki.com/v753/free/...pg?1174256044]
Old 03-18-2007, 05:32 PM
bhop73's Avatar
bhop73 bhop73 is offline
Re: help with fixing glass after paint leaked on it
Don't be nervous. If anything, you'll make it even more shiny than it was.
http://www.bhop73.com/
Old 03-18-2007, 10:21 PM
MidMazar's Avatar
MidMazar MidMazar is offline
i would start with 800 and go up to the highest you got.
In Progress
Old 03-19-2007, 06:33 AM
wouter1981 wouter1981 is offline
I think 800 is to coarse to begin. I would first try if you can't get most of the paint off the glass with just a toothpick. If this succeeds, you can start with a 4000 gritt... if it takes to long, go to something coarser.... better safe than sorry.
Old 03-19-2007, 09:55 AM
ZoomZoomMX-5's Avatar
Yikes; this is one reason I don't paint glass anymore and do the black masked areas with a chisel-tip Sharpie. It's very easy to control, and if I want flat black paint for interior detail I'll brush on acrylic flat black paint over the Sharpie. If I had to spray paint the black I'd use flat black acrylic so it could be cleaned up with window cleaner or alcohol.
You might be able to polish out the marks w/o sandpaper. Tamiya coarse, fine, and finish may very well do the job. Or Meguiars Scratch X.
800 grit is too coarse; 1500 or 2000 automotive wet/dry might be better, or start with 2400 grit polishing cloths and go all the way up to 12000 before using liquid compound.
My Fotki Album
Old 03-19-2007, 12:30 PM
lemansnut lemansnut is offline
After you finish polishing out the paint bleed-over, try giving the windshield a coat of Future. You'll be amazed at how much clearer it will appear. There's a "how to" article about this in one of the latest Finescale Modeler magazines.
Mike
