anyone can help me please to program the keyless for my yukon 2001
all tese stepe are made and nothing is happend the remote is gm/uta 15732803 Any suggestions , thank you 1. Close all vehicle doors. 2. Insert the key into the ignition. 3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release. 4. Perform steps 5 through 8 in fairly rapid succession. 5. Turn the ignition switch to the ON position (as far as you can go without starting the engine). 6. Turn the ignition switch to the OFF position. 7. Turn the ignition switch to the ON position. 8. Turn the ignition switch to the OFF position. 9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically. 10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds. 11. Repeat step 10 NOW for each additional transmitter (including any existing transmitters). 12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode. |
Re: 2001 yukon keyless
Sounds like you have the programming for the 2003 & 2004 Model. I don't know of they are the same though.
Instructions are correct for the 2001 Yukon as shown in post 1.
The correct remote is as follows: FCC: KOBUT1BT Canada: 1983 101 393 Part #: 15732803 ![]() http://originalkeyless.com/2001-GMC-...?categoryId=-1
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
