Old 03-18-2007, 03:20 PM
X2Xtreme360 X2Xtreme360 is offline
door insert question
I'm in the process right now of fabricating some color on my doors. Does anyone know the process of fabricating the upper fabric (carpet like material) on the door panels? It seems like it's all just one peice is it held on with an adhesive or something?
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 03-18-2007, 04:50 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: door insert question
If its just the base then yes it is held in with adhesive.
Old 03-18-2007, 09:05 PM
If by base you mean the bottom peice that covers the screws that hold the panel to the door then no, I'm talking about the one next to the door handle.
Current mods:
Cold air intake
Polished Plenum
Old 03-18-2007, 09:26 PM
Stealthee's Avatar
LOL, No I meant base 3k. The carpet panels up top that came on base Stealths and base 3ks are glued on. The leather ones that came on SL's, RT's, TT's, and VR4's in clipped on.
Old 03-18-2007, 09:27 PM
youngcaradvc youngcaradvc is offline
Are you looking to replace that peice or color it? Im pretty sure its helf be adheisive but it also may be stiched on? Im not too certain, Im looking to do interior to and this info would be beneficial if anyone knows. Take off the door panel and take a look behind that section.
Old 03-18-2007, 09:30 PM
Well looks like I got the cheap end of the deal lol. I DO have an SL, but it's the carpet and not leather. Is there any way to remove them with heat or something, or do it with the peice still attached or am I kinda screwed and have to buy a VR4 panel?
I have the panel off my door it's actually sitting right next to me lol. It is indeed all one peice.
Current mods:
Cold air intake
Polished Plenum
Old 03-18-2007, 09:32 PM
The carpet near the bottom is screwed on I thought, you could do it the easy way, but you risk damage.
Old 03-18-2007, 09:39 PM
No not the bottom peice the top peice. But anyway, if you do happen to be lucky and wanna do leather inserts on a clipped on version of the panel, here's a link I found on how to do it.
http://www.diynetwork.com/diy/shows_..._33677,00.html
As for my SL, I'm not too sure where to go from here. I'm gonna do the bottom for sure, but it won't match the top if I don't do that so I have to find a way.
Current mods:
Cold air intake
Polished Plenum
Old 03-18-2007, 09:43 PM
Yeah the top really would complete everything. I would personally probboly just cut it out, I dont see any other way to do it, if theres no way to really loosen the adhesive and no bolts then thats the only thing left. good luck I know i will be doing this within the next week or so, im going white and black.
Old 03-18-2007, 09:53 PM
Well being as impatient as I am, I got it off. All it is on the SL is the fabric material adhered to a lining of vinyl material underneath it and it's all glued to the actual door panel. Honestly I think this should be easy enough. I'll prolly reuse the original vinyl underfabric to adhere my new fabric to it, the adhere that to the door panel and use a flathead to tuck it nicely in place around the edges. I just used a flathead to pull a corner of it up and it peeled off pretty easy.
Current mods:
Cold air intake
Polished Plenum
Old 03-18-2007, 10:59 PM
Good to hear u got it off, where did you get our interior kit off of? I plan on buying mine off of some guy on ebay for 105 shipped, hes got good reviews and it looks pretty legit.
Old 03-18-2007, 11:19 PM
Well as far as the door inserts go, top and bottom, I'm doing those myself. No kit. The only think I'm undecided on is what to use. I've never been a huge fan of leather, even though leather inserts might not be a bad idea, but I'm not sure yet. I don't know what material to use, but it's prolly gonna be along the lines of the original material, just dark red. I also might dye my door handles dark red as well (if anyone knows of some good vinyl dye, let me know. I don't want it fading off if I decide to do it.) If anyone has any other cool ideas as far as material is concerned, feel free...
Current mods:
Cold air intake
Polished Plenum
Old 03-19-2007, 11:24 PM
Here's my first attempt on the driver side door panel using red vinyl fabric:
I think it turned out pretty nice. This is the first time I've ever attempted something like this. I'll have it installed tomorrow after a little "tack" cleanup.
If anyone wants a write up with pictures when I do the passenger side, let me know and I will. All the materials cost a total of about $15 for a quarter yard of vinyl (enough to do both doors and then some.) and some very strong adhesive.
Current mods:
Cold air intake
Polished Plenum
Old 03-20-2007, 10:08 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Looks very good for a first try especially. I wouldnt mind looking into that myself, but I'm eventually getting new two-tone leather for my seats and I beleive it will come with new leather for the inserts.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 03-20-2007, 05:20 PM
Stealthee's Avatar
Looks real good. I may attempt something similar in both the Talon and the Stealth
