Old 03-18-2007, 01:15 PM
batman_127 batman_127 is offline
help!!!!
i just got the idle in my van to work but now i can not get the gas pedal to work it is stuck all the way down and it wont give the car any gass i tried putting it in gear to see if that might work but no i had to take off the trottle body to fix the idle does that have anything to do with it and if not how do i fix it
Old 03-18-2007, 02:07 PM
Millermagic Millermagic is offline
Re: help!!!!
Kinda sounds like your throttle cable came unhooked from the throttle body.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 03-18-2007, 02:20 PM
Re: help!!!!
i dont think so i put every thing back together the way it was is there anything else it could be?
Old 03-18-2007, 06:57 PM
Angry Re: help!!!!
ok throttle cable is hooked up same problem persisting any thoughts
Old 03-18-2007, 07:29 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Re: help!!!!
Is the throttle cable routed exactly the same way as it was before you fix the idle probem? It could be binding...
The cable could also be broken or disconnected from the gas pedal!
You could have a helper sit on the drivers place and step on the gas pedal while you look from under the hood and see if the throttle cable moves as he depresses on it. The same thing works in vise-versa, you could move the throttle by hand from under the hood and have a helper check if the accelerator pedal moves inside.
If the cable moves when you do this, then another thing would be to take the air cleaner and air duct off and see if the throttle plate moves when your helper steps on the gas pedal... that could be costly to repair if in fact is broken...! good luck
Old 03-18-2007, 07:41 PM
busboy4 busboy4 is offline
Re: help!!!!
Hi,
I would carefully check to make sure you think the cable is hooked up properly - over the "half circle" cable guide and that the cable is taut once hooked up. I can't really see how it can be properly moving the throttle plate open and closed, yet causing no change at all in engine speed. There is an additional spring as I recall that is removable between the throttle body and "support bracket" for the throttle/cruise control cable. Is that in place? As I recall to re-install the detached throttle cable on my '96, I have to physically hold the throttle full open, and pull on the throttle cable in order to slip the end into its slot on the throttle actuator.
Sorry, but I have to agree that the most likely cause would seem to be a problem in how you re-installed the cable.
Let us know what you find.
Best of Luck
Old 03-18-2007, 08:16 PM
12Ounce 12Ounce is offline
Re: help!!!!
If the throttle plate is moving, but the TPS sensor doesn't send info to the PCM there will be no increase in fuel .....???? Is the TPS hooked up ... or possibly not working??
Old 03-19-2007, 10:45 AM
Re: help!!!!
HI
I wondered so..........I disconnected the TPS on my '96 while it was running. No change in idle, responded normally to throttle movement. Guess the MAF must pick up the slack.
Old 03-20-2007, 08:06 AM
bbonifant bbonifant is offline
Re: help!!!!
Maybe someone can help me on this. When I did the upper intake repair and reattached the throttle cable, I noticed that it was frayed a little. I don't know how many small cables are twisted together to make the whole throttle cable, but 2 of them broke. Is there an easy fix or do I need to see the mechanic? I'd hate to have the thing snap while my wife is driving. Thanks,
