Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-18-2007, 12:57 PM
chopper1982 chopper1982 is offline
Send a message via MSN to chopper1982
speaker wiring problem
I have a 99 tahoe 4 dr and i put a new deck in it and i cant get the rear door speakers to work has anyone had the same problem
Old 03-18-2007, 04:12 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: speaker wiring problem
Have you checked to see if the speakers work? Are you getting power to the speakers? Have you checked the wiring again to make sure that you got it correct? Did you use an adapter harness or did you hard wire the new deck in? Maybe you got a defective deck and it is not sending power to the speakers.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 03-18-2007, 05:15 PM
i checked the system with the factory deck and they worked and i used a wiring kit, But is there a chance that theres 2 different kits one for a 2 dr and one for a 4 dr? and the deck is working fine. Its the fact that my tahoe has a 6 speaker system due to the extra doors
Old 04-05-2007, 09:13 PM
ROYZELL ROYZELL is offline
well i know u probably got your radio figured out, but if not take the blue antenna wire and connect it to the red(hot) wire, they should come on!!!
Old 04-23-2007, 04:10 PM
1987ss's Avatar
1987ss 1987ss is offline
had smae problem there is a factory amp on only those doors, dosent make sence but there is a blue wire you need to hook up your remote wire to and the will come on...
