Old 03-18-2007, 11:34 AM
chopper1982 chopper1982 is offline
Send a message via MSN to chopper1982
need wiring help
I just got a 99 tahoe and I put a stereo in it. the prob i have is that my truck is a 4 dr and all the wirig kits i found are for 2 dr I need to know which wires are for the back door speakers because the front and rear speakers work
SOME ONE HELP
Old 03-18-2007, 04:26 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: need wiring help
I would think the wiring harnesses would work for both, but it's just a guess.
Old 03-18-2007, 04:30 PM
but the question is there a chance that theres another kit that would include the rear door speakers?
Old 03-18-2007, 08:45 PM
PlayStation3 PlayStation3 is offline
well most aftermarket hu use front and rear and sub so if you have speaker in the back back part then use that as your rear and just splice the harness to make is so that normal front ones are connected to the other doors one but keep the left side with the left side and the right side with the right side.
Old 03-18-2007, 08:52 PM
my hu only has a sub out no rear or front and im trying to splice in with the after market wiring kit i just need to know witch wires on the factory are for the rear door cause i tryed a bunch of different ways but nothing worked
Old 03-18-2007, 10:09 PM
dbfreak147.5 dbfreak147.5 is offline
there was a guy on termpro that had the same problem let me look and see what he had to do, course his were in the hatch but i'm sure it would be close to the same solution
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-18-2007, 11:50 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
I take it you have 6 speakers. And it sounds like only 4 are working, if this is the case you wont get the other set owrking unless you amp them.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 03-19-2007, 12:56 AM
1987ss's Avatar
1987ss 1987ss is offline
just had the same problem hook up the remote wire.. i got a 99 tahoe and back seat door speakers wernt wokin and i was confused they worked fine with stock deck but not after market .... check out this thread http://www.automotiveforums.com/vbul...d.php?t=146977
this will hopefuly help you!! i was pissed off to i know how you feel!! post back i can open my dash and send you pict if you dont get it..
Old 03-19-2007, 05:40 AM
Audio Guy
try this ... http://www.installdr.com/Harnesses/GM-Wiring.pdf
Old 03-22-2007, 09:14 PM
hay thanks for the tip it work like a charm, But whats the deal with only those 2 being hook to an amp? but any way thanks for the help worked great
Old 03-22-2007, 10:29 PM
1987ss's Avatar
? i dont know, if you find out please post it...
