Old 03-18-2007, 09:44 AM
wileygirl wileygirl is offline
My key will not turn!!! HELP!!
Ok, I have an emergency here....my key will not turn out of the OFF position.. won't even budge... any quick suggestions would be helpful (i'm not a real car expert)(annddd my car's stuck in the grocery store parking lot right now..) please help!
Old 03-18-2007, 10:02 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: My key will not turn!!! HELP!!
The most common problem of this type is usually in the shift release mechanism. I'm assuming it's a floor shift. If so, the button you push with your thumb is sticking causing the lock to think it's still not in "Park". Turn the key to the 'ON' position. Then try pushing that thumb button a few times allowing it to snap in and out abruptly. After that, then try working the key from 'On' to 'Off'. That should release the key after a few tries of this sequence. Ultimately, you will need to get some lubricant down inside the spring loaded interlock mechanism inside the console.
Old 03-18-2007, 10:07 AM
Ill try pushing the button again, but I can't turn the key to ON yet because it wont move from OFF at all.
Old 03-18-2007, 10:16 AM
dugan50's Avatar
Authorized Vendor
It sounds like you have a bad lock cylinder then. Last option, I would suggest is that you gently tap the end of the key into the lock witha small hammer (as if is wasn't going in far enough). Sometimes this loosens up the tumblers in the lock and allows the lock to move. If that doesn't work, then you need to replace the lock cylinder and key
Old 03-18-2007, 10:45 AM
Actually, since it may have something to do with the shifter, its probably important to mention that my button is broken and pops out easily. I did try pushing it multiple times, and trying to budge the key.. but no luck.
Old 03-18-2007, 12:59 PM
ugghh.. I guess i'm gonna have to get it towed somewhere....Thanks for your help! If anyone else has any ideas, i'll be checking frequently.
Thanks again!
Old 03-18-2007, 01:41 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Put it in "neutral" then try turning the key.
You Probly need to get that button on the shifter fixed too.
A used shift lever would probly work.
And a new lock cylinder isnt out of possibilities either.
and Welcome to AF wileygirl .
1999 Grand Am SS 3.4 OHV
Old 03-20-2007, 07:18 PM
Alright, here's the verdict. I had to get a new ignition cylinder...total $400 +
Not a pleasant experience.. i missed my car .....but now she's all better and I'm broke!! Thanks for all your help guys!
