Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 03-18-2007, 08:28 AM   #1
maxman
99 Lumina LTZ 3.8L Coolant level sensor?
OK, I give up. Where is the low coolant sensor? The "Low Coolant" light stays on. Coolant is not low. I've looked all over the radiator and all over the "over flow" tank. I can not find a sensor or even wire leading to either. At one point, to tried to fix this. I flushed the coolant system and recharged. The light went out for awhile, but came back on again and it stays on.
Thanks in advance.
maxman is offline   Reply With Quote
Old 03-18-2007, 11:40 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: 99 Lumina LTZ 3.8L Coolant level sensor?
Did you look under the overflow reservoir? Some are located there. You may have to unbolt and move the PCM to see it all.
Blue Bowtie is offline   Reply With Quote
Old 03-19-2007, 04:50 PM   #3
pdigital360
I have a 98, which I assume is the same.
Look on the passenger side of the radiator towards the top, kind of behind the headlight. I need to replace mine too but just havent gotten around to it.
pdigital360 is offline   Reply With Quote
Old 03-19-2007, 05:08 PM   #4
richtazz
stupidity should hurt
richtazz's Avatar
It's located in the passenger side radiator tank, about 1/3 the way down. It's about 1-1/2" square and has a 2 wire oval connector.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
richtazz is offline   Reply With Quote
