1992 Camry brake light trouble
A friend of mine is having trouble with brake lights on 1992 Camry. What could it be?
Re: 1992 Camry brake light trouble
What specific trouble is he having? Possible causes:
> Bulbs > Fuse (not sure if there is a separate brake light fuse) > Corroded bulb sockets > The brake lamp switch on the brake pedal lever > The light failure sensor in the trunk > Wiring
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
It flexes every time you open the trunk. After cutting open the sheathing I found a couple of wires that broke with light finger pressure. Soldered in a replacement wire section, then later had to go back in again for additional wire breakage. This time I spliced in an new length of wire for each one, coiling the new wires around a Phillips screwdriver to create a wire coiled like a telephone handset to better resist repeated flexing. So far, no problems. |
