Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-17-2007, 08:52 PM
jake jake jake jake is offline
Bad park-neutral switch on 89 4x4 automatic pickup
i have a 89 4x4 automatic V-6 deluxe pickup truck and the shifter on the console gets stuck in PARK alot.
I also have an intermittent starting problem on the 4x4.
the battery and battery cables and starter are fine, but i am guessing that the intermittent issue might have to do with a bad park-neutral switch on the vechicle.
i remember my shifter getting stuck in PARK many times and it was hard as heck to get it to move into DRIVE.
It would just jam in PARK. I would literally have to manhandle it very roughly to get it out of PARK into DRIVE. Is this what they mean by a bad park--neutral switch?
and do you have to replace the whole SHIFTER to replace the park-neutral switch in a 4x4 89 V-6 Toyota deluxe pickup [xcab], or is the park-neutral switch just a tiny little part in the shifter assembly?
is it expensive to change the park-neutral switch? is it a major job that takes a few hours at the shop??
Old 03-21-2007, 11:19 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Bad park-neutral switch on 89 4x4 automatic pickup
Having to manhandle the shifter sounds like a mechanical problem, maybe in the shifter/linkage assy, possibly the trans.
The neutral start switch is usually in the shifter assy, but it is mounted down on the trans on some vehicles. It's usually a simple job to replace.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
