Old 03-17-2007, 07:34 PM
ironman85's Avatar
ironman85 ironman85 is offline
Send a message via Skype™ to ironman85
trying to decide on a b series to get/boost
I am in the market for a 88-91 CRX, just waiting to find a good buy in my area. i'm getting everything worked out currently as far as stages and the swap goes. done plenty of searching/reading but i would appriciate help figuring out which engine would be best for me. the rex would be my extra car, so down time isn't an issue, neither is daily drivability.
i plan to boost a few months after i do teh swap along with moderate cams, etc.
i have a h23 in my garage.....but because of size and some missing pieces i decided against it
b20 is out cause it has less potential for boost.
so i am looking at
1988-1991 JDM B16A
1992-1993 USDM B17A1
1990-1991 USDM non-VTEC B18A1
best as i can tell these 3 would be best for me. almost all are in my price range, low compression, cable tranny and/or OBD0
if u can post any info u know on these engines/personal experiance/potential for boost/weaknesses would be great.
but plz no "b16s are overrated" "my stock d16 pwned this b20 swapped crx" flamming/random statement crap. at least this isn't hondatech, so there shouldn't be much of that stuff anyways
Old 03-17-2007, 10:46 PM
arodg25's Avatar
arodg25 arodg25 is offline
Re: trying to decide on a b series to get/boost
well my vote is for the b18a1. if your boosting you dont need vtec.
Old 03-17-2007, 11:12 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Being a b16 owner im going to vote b18 for boost. If you want to do some very simple engine work you can make an ls/vtec setup that will make it very reliable, and have PLENTY of power. otherwise itll still have more torque than the rather undertorqued b16.
The b17 will be near impossible to find btw.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-18-2007, 12:41 AM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Definitley B18a. Has the most potential for boost or a vtec setup. Basically the weaknesses of this motor is its stock connecting rods and rod bolts, both of which you should change for a turbo setup anyway. Its head is also weak in terms of flow which can be fixed by slapping on a B16 head. But right out of the box, you should have fun with the motor before saving up and doing any upgrades.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 03-18-2007, 01:18 AM
FrodoGT's Avatar
I will say that my b16 is a tough little bugger though..I doubt I could kill it without boost.
Current project:
Rio Red 91 hatch.
Old 03-18-2007, 01:59 AM
So are all other Honda engines.
Old 03-18-2007, 08:23 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
True, I raced a D16Z6 with bad rings all year and I swear it started running stronger toward the end of the year. It would smoke like a freight train until I hit the track and did one lap.
Oh yea, I would go for the B18 as well, shouldn't be that hard to find either.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-19-2007, 12:57 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i say use the H23
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-19-2007, 01:29 PM
Originally Posted by BLU CIVIC
i say use the H23
Too many conversion/ wiring/ mounting/ fabrication/ and tranny issues, especially for someone who is new to swaps. Stick with either a B, like said above, or a turboed D.
Old 03-19-2007, 01:32 PM
BLU CIVIC's Avatar
調整器
not ture anymore...mabey about 3 years ago
but to start out i'd build and boost the D first
The name's Adrian
2011 CR-Z - Stock
Old 03-19-2007, 01:34 PM
I just noticed you said this and this is not entirely true. B20B's have low compression (like 8.8:1) and basically have the same head as an LS. They can be good candidates for turbo if you sleave them and build the bottom end a bit. You can use all the hardware and sensors from an obd0 b18a and throw it into a 4th gen. Just make sure you don't get a high comp B20z if you are looking to turbo.
http://www.ef-honda.com/ben/EFB20swap.php
Old 03-19-2007, 07:56 PM
ironman85's Avatar
would rather not have to sleave and build the bottom end before i could boost. i want to be able to trust my engine, and if i didn't build the b20 first, i wouldn't trust it. not out of experiance...but from ppl talking about it. maybe u can talk me into it lolol
and i want to mention this. u guys are much more helpful friendly then the ppl on hondatech. too many ricer nubs, or ppl who have dealt with teh nubs so long that they are bitter and mean. and just too much activity to get the help u need. this feels more like my home ( CB7tuner.com )
quick side question. seen several post about VTEC and boost kicking in at same time...and that VTEC is wasted then. any truth to this? i don't see how that could be right.
since the B18 i am looking at is non-VTEC would be helpful to know. looking over ls/vtec info incase it would be a good thing.
Old 03-19-2007, 08:13 PM
Whats honda-tech?
Its good to have your VTEC crossover point different than when you spool.
Old 03-19-2007, 08:28 PM
ironman85's Avatar
kk, so not that boost kills vtec(didn't think that sounded right), just need to have the power from them come at different times. got it
Old 03-20-2007, 07:26 AM
BLU CIVIC's Avatar
調整器
if you're boosting, then you don't need Vtec...if you're going to use the D series, check out www.turbod16.com ...think that's right...don't bother joining and asking questions b/c they won't answer...very helpful information section
The name's Adrian
2011 CR-Z - Stock
