Old 03-17-2007, 02:17 PM
vrmlbasic vrmlbasic is offline
Question Lowering the Thermostat
On cardoman I see a lot of people putting thermostats which open at 15+ degrees lower than the stock thermostat....is there any real advantage to doing this?
Is there a real disadvantage? I can see that the coolant would be pumped through starting sooner, but that doesn't seem to be that much of a disadvantage, though I may be missing something (and that's why I'm calling out to you guys for an answer)
**Of course, most of the people doing this are putting full-trunk speaker cabinents in their rides, along with multiple amp capacitors and speakers which are so loud you can hear them with perfect clarity on the other side of an 8 lane highway......
(so I'm taking anything I see there with a jar of salt)
Old 03-17-2007, 03:00 PM
maxwedge maxwedge is offline
A990 racer
Re: Lowering the Thermostat
Stock engine? if so they run best at 195 as designed.
Old 03-17-2007, 04:34 PM
So there's no real advantage to dropping it down to 180 dF?
What would happen if you lowered the opening temp of the thermostat? (other than the engine will 'run cooler')
Old 03-18-2007, 09:14 AM
A990 racer
The engine would take longer to go to " closed loop".
Old 03-19-2007, 10:17 AM
Luke. Luke. is offline
And as additional input, my understanding is that the PCM remains in 'open-loop', until the coolant temperature sensor (ECT) reaches, atleast, 68 degrees F, and the oxygen sensor reaches an operating temperature of 600 degrees F. Once both conditions are met, the PCM switches into 'closed-loop' fuel control operation.
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired
& 1995 Saturn SL2 (498,125 miles) as of 6/19/07
