Old 03-17-2007, 01:29 PM
philburt149 philburt149 is offline
Door panel removal
how do i remove the door panel to get to the speakers on 1998 s-10 ext. cab? Or do i even have to remove whole door panel to get to them?
Old 03-17-2007, 03:27 PM
Re: Door panel removal
nevermind, found it
Old 04-21-2008, 11:15 PM
dksram
Guest
Posts: n/a
Where? I need to know also.With manual crank.
Old 04-21-2008, 11:38 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
If you have manual windows you might need a special tool to remove the crank. Other than that, remove the plastic behind the door handle (held on by one screw), pop the window switch plate loose (may not be nessesary on manual window panel), pry the panel loose from the door with a screwdriver (plastic clips all around the edges), then lift the panel up and off the door.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-22-2008, 12:29 AM
dksram
Guest
Posts: n/a
Well I searched several forums and it seems nobody has photos.
I will be installing my R/H side mirror tomorrow and will be taking step by step photos. Well it will step by step by dmhoo29
