Old 03-17-2007, 11:16 AM
NdaSHADOW NdaSHADOW is offline
License Plate Light
I have a 02 and the rear license plate light (left side) only works after I tap it. 1) Is there a quick fix other than die grease? 2)How do I get the assembly out to replace the socket if necessary?
Thank You
Old 03-17-2007, 11:19 AM
rodeo02 rodeo02 is offline
Re: License Plate Light
The clear domes are held in place by screws. These lamps take a beating with with the slamming of the liftgate. Usually a bulb reseating will fix it. If the lamp holder needs to be replaced you have to pull the interior panel off the liftgate to get at the wiring.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-21-2007, 07:11 AM
MCOM12 MCOM12 is offline
I have the same problem. How exacltly do you reset the lamps without removing the interior panel on the tailgate? Thanks for the help
