Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-17-2007, 09:31 AM
graygoose919 graygoose919 is offline
my 96 saturn wont start
hi, i have a 1996 saturn 1.9 2 dr. coupe. i went out to start it and i get nothing.it doesnt turn over at all. i hear the fuel pump turn on, i have lights, and radio.i've checked ingition fuses under hood and under dash. i changed the starter about a year ago. i've tried to jump, but got nothing. it doesnt turn over, or click absolutly nothing.
Old 03-18-2007, 10:06 AM
yaz4real yaz4real is offline
Re: my 96 saturn wont start
Is it an automatic or standard transmission?
If automatic, make sure you are in Park... jiggle the shifting lever.
If a manual, it may be you clutch safety switch.
Also check for clean and tight battery cables. Don't assume by just looking at them. Use a 8mm socket at the terminals. Take off both, look, clean and reapply. Do not overtighten.
Old 03-18-2007, 04:52 PM
thanks for the advice yaz4real. i figured it out it was my starter. sent power straght to it and nothing. one hour $120.00 later problem solved
