Old 03-16-2007, 11:44 PM
chevyluver37's Avatar
chevyluver37 chevyluver37 is offline
1989 s10 knocking
i have a 1989 s10 with a 2.5 liter 4cyl with 199000 miles almost all hwy and i just recently put new high flow exhaust on and it has developed a really bad knocking worse than just the normal old worn out engine knocking and pinging but it only really does it when im going down the hwy and i try to excelerate in 4th or 5th gear ive checked the water and it is good it uses a little oil but i keep up on it regularly other than that i dont know any help would be good i dont really want to put a 350 or other v8 in it because i still am getting about 30mpg so and parts info or repair info would help try to keep in mind i have a small buget thank you
Old 03-17-2007, 02:25 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: 1989 s10 knocking
It sounds like you have a bad case of pinging. Check the timing with the timing wire under the glove box disconnected and make sure the timing is within specs.
Old 03-18-2007, 01:13 AM
timing wire under the glove box huh? kinda confused about that one im only used to old vehicles
Old 03-25-2007, 03:34 PM
gmctruck06 gmctruck06 is offline
the connection Delcoch is talking about is behind the carpet under the glovebox. Disconnect that and then do a timing check.
