Old 10-08-2002, 06:34 PM
tye112's Avatar
tye112 tye112 is offline
messed up my console! help.
i just bought a used console for my car. by console, i mean the peice that holds the rear ashtray, to the ebrake, and up to the shifter.
i was in the process of removing my previous console, and i was having difficulties unscrewing the bolts which hold it down. me being the idiot i am, decieded i would just turn has hard as i could, and it stripped the bolt to aboslutey nothing. i call the guy who i bought it from, Jeff (90CivicRider), and he suggested i just loaded it up WD40 and try unscrewing the other one like that, heh. I tried, just stripped the shit out of that one too.
I was thinking that there may be another bolt on the other side or osmething hold it on...i'm not really sure, but i had no luck doing it on my own.
So pretty much, i am screwed into keeping this ugly destroyed console right now. I have no clue what to do, everyone else i have asked, hasn't a clue either....HELP ME!!!
Old 10-08-2002, 07:27 PM
EF9JDM EF9JDM is offline
Send a message via AIM to EF9JDM
you can get a drillbit type thing that will take strpd bolts out at the hardware store
90 civic si
<Keep It Simple Stupid>
Old 10-08-2002, 07:52 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Can you get vicegrips around the head of the screw?
Old 10-08-2002, 08:29 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Okay. In your center console, there are 4 screws. 2 underneath the e-brake (under the rectangular beauty cap), and 2 up towards the front of the console (one on each side). Neither of these should have a nut on the other side, the two up front just screw into a plastic clip, and the 2 under the e-brake go into threaded bungs ([beavis]huh-hu he said "bung"[/beavis]).
I don't understand why you're having so much trouble with the screws (sounds like you're working on the two up front). You can go to the hardware store and buy what's called an "easy out" or "screw extractor". Then, what you have to do is drill a hole in each screw down through the threaded part (probably about a 1/4" deep. Then, you put the screw extractor in the hole and use a wrench to twist it. It's designed to grab the inner wall of the hole you drilled, and you just unscrew it...
If you aren't planning on keeping your center console, just hack away at it with a dremel tool or something...
Old 10-08-2002, 08:35 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Just drill out the screws.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 10-08-2002, 08:38 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Yea, i did this too!!! I have the same problem, and now with the teg console coming, i am gonna just take my dremel and drill off the heads of the screws and take the console out, then when i put the teg console up, i dont know if the holes are gonna be in the same place or not.... So if they are in the same place, i'll just get the screw extractor from the hardware store, if not, i'll just put in the teg console like i am suposed to.....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-09-2002, 12:52 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
I guess he got it installed. Now his shifter sticks upto high..lol
easy fix, a shift knob should do the trick. He's got the Hurst shortshifter with the stock shiftknob.
oh yeah, and Welcome to the board Tyler.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 10-09-2002, 07:04 PM
tye112's Avatar
well, i went out and got a new carbon fibre shifter knob....it sits up even higher than the other one . I think i've figured out a way to fix the problem, but it looks like trash right now :P
Old 10-09-2002, 07:06 PM
tye112's Avatar
and if anyone wants to give me some suggestions for a interior scheme go right head.
my goal is eventually to paint my exterior baby blue. i have my ebrake console thing, and my stereo console thing painted white as of now, and my door speaker enclosures and door handles....
not sure what i should continue with, with my colors, or what thigns should be what colors....heh,
lemme know whut u think
