Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-16-2007, 04:15 PM
that_guy5's Avatar
that_guy5 that_guy5 is offline
check engine light code
i have a 98 civic dx auto and it has check engine light so i decided to run the codes. i was wondering if u guys would help me out. it picked up 5 codes
1) p420-catalyst efficiency below threshold (bank 1)
2) p0301-cylinder 1 misfire
3) p0302-cylinder 2 misfire
4) p0300-random/multiple cylinder misfire
5) p1456- manufacturer control auxiliry emission control
well when i turn on the car for the first 10 sec. or so it acts like it wants to turn off like its choking or something but then after it reaches a higher rpm it goes back to normal, it also been wasting alot of gas recently but other than that it runs fine. hope u guys could help thanks
Old 03-17-2007, 09:10 PM
240slider's Avatar
240slider 240slider is offline
Re: check engine light code
how many miles do you have on the car ? If under 80k the cat maybe still covered under factory warranty.if not p0420 means you need a cat .the p0300 reconizes there is more than one cylinder misfiring .the p0301-4 indicate the cylinder.the p1456 is related to the Evap system indicating a small system leak (check gas cap) .you may need a tune -up .
Old 03-19-2007, 12:56 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Forget about the P420, P300 and P1456 for now, those are the codes that
comes along with the 2 misfire codes. Your main concern is to find out what is causing your engine cylinder 1 and 2 are misfiring, once you fix that and clear the codes than you will be fine.
Check your cylinder 1 and 2 sparkplugs and wires first and see what you can find.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
