which tranny do i have?
I have a 2000 silverado LS extended cab 4x4. 4.8L engine. how can i find out which tranny i have?
Re: which tranny do i have?
I think 4L60E is the only automatic offered on the 4.8. The pan on it should be square.
//2000CAYukon |
![]() Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft |
What's the difference in the 4l60 and 4l80? which trucks got the 80? can i get a stronger one?
Biggest difference between the 60e and 80e.... Size, the 80e is damn near bulletproof. The 60e not so much. HD's and I believe the AWD SS came with the 80e. A conversion is available and relatively cheap outside the price of the 80e. Only a new crossmemeber and harness are required (I think). What I would like to see is someone do a 4l60e to 6l80e conversion.
2004 Silverado Half-Ton Crew 7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block 3" PA Body Lift Yukon 4.88's with Auburn LSD Xentec 6500k HID lows, Silverstar Ultra brights Wade in channel window vents Covermaster Top Flowmaster 40 series, dual outs Nelson 89/91 HOT TUNE 20" MB Gunner 6's, 37" Toyo Open Country MT's Eclipse AVN6600 w/sirius and IPOD controllers Code Alarm w/ Remote Start |
The awd silverado ss came with a 4l65e. A 4l60e can be made to hold alot of horsepower, and several performance trans companies build them. Flt makes the level IV 4l65e that is damn near bullet proof. Alot of guys building these trucks to go fast are going to the 4l80e. Speed engineering makes a full 4l80e conversion, which includes the driveshaft, trans brace, converter, trans, and wiring harness upgrade, but it isn't cheap. For most applications, the 80e is overkill, because it will rob a good bit of power from your stock power. I'd look into getting a build from FLT, teamtripp,etc if you want to keep the 4l60e or upgrade to the 4l65.
I have a 2004 V.H.O. rwd which - like the SS awd - has the 4l65E. Can you tell me how mine differs from the standard 4l60? Is it heavier weight components or a different design entirely? About all I know of it - is it was designed to handle the heavier load/torque needs that the 6 liter high output engine puts on it. Thanks for any info given.
. . . .>>>>> . .White Lightening . .<<<<< ![]() ![]() More pictures??? Link below shows them & a list of features and options on this 2wd SS V.H.O. http://files.automotiveforums.com/ga...ite+Lightening |
thanks for all the help i'm gonna call a couple of shops including the local dealer next week and see how much for a new tranny.
Same idea, new question:
I have an 04 2500HD w/ a 6.0 Gas - what auto trans do I have? Thanks |
1500 = 4L60E
2500 = 4L80E Bert |
You could also beef up the clutch pack and add a shift kit to a 4l60e and have a pretty good tranny. Unless you are going to be making a lot of hp and torque or pulling/hauling a lot of weight then the clutches and shift kit will do you good. BTW if you don't service the tranny, no matter the tranny, you are going to kill it. For more info on shift kits for the 4l60e see http://www.transgo.com/sk_generalmtrs.php
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
2014 Ram 1500 Crew Cab |
We're dropping one out of project Zeus next weekend to put in a fuddle 2800 converter. Man, I'm not looking forward to dropping that pig of a tranny/converter out of that truck.
