Old 03-16-2007, 09:57 AM
mjtr21 mjtr21 is offline
no cruise control
i was driving along the highway the other day and i went to use the cruise control and it didnt work. i believe it is vacuum operated but not sure. also my 4WD does not engage the front wheels either. could those two be related in some way? thanks.
Old 03-16-2007, 10:08 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Re: no cruise control
What make, year and engine code is your vehicle?
Old 03-16-2007, 10:14 AM
oh sorry its a 1997 GMC Jimmy with the 4.3 engine.
Old 03-16-2007, 11:21 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Sounds like a vacuum problem.
Check the small hoses from the vacuum ball to the manifold and to the transfer case.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 03-16-2007, 12:35 PM
okay thanks. so if i replace one thats leaking it could help fix my 4WD problem? i will check when my brother brings my truck back here.
Old 03-16-2007, 03:21 PM
Quite possible.
Because both the cruise and 4WD work off vacuum assist, I'd guess a cracked or disconnected hose from the manifold to the vacuum ball.
Old 03-18-2007, 12:23 PM
okay i will check today. yesterday was snowing really bad and i couldnt get out to check it. i also notice when i am slowing down to a stop the rpm's fluctuate, so i guess this is related to my vacuum problem. thanks.
Old 03-19-2007, 09:37 AM
Snilloc Snilloc is offline
i think my blazer may be having the same vacum loss problem. my cruise stopped working over a year ago, and recently my 4x4 stopped engaging. Checked the vacum actuator and had no vacum going into the solenoid. So i'm guessing i have a leak going from the manifold to the vacum ball. I'm not the most mechanically inclined, but is this something I could find/fix on my own? Any help would be apreciated.
Old 03-19-2007, 02:14 PM
old_master's Avatar
Advisor/Moderator
Cruise control does not use vacuum, it is all electronic. Check connectors, fuses and control cable where it connects to the throttle linkage.
Old 03-19-2007, 04:09 PM
yeah haha i kinda realized that when i didnt see any vacuum hoses coming out from the servo motor. thanks i will check fuses and the connector.
