Old 03-16-2007, 12:32 AM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Gateway doesn't work after Blackout
This has not happened many times at all, only when the power is shut off not purposely or it's been shut off for like 2 months, but when I tried to turn it on (after a planned power grid restart, accidentally left PC on when I was away tonight) it powers up with the fan REALLY loud, but the bios doesn't work, nothing loads, it doesn't power up the monitor/keyboard/etc.
The first time this happened, I took the Tower to BestBuy and they tested it and said nother was wrong with it, so I thought my surge protector was too old so I bought a new one and it worked...then another 2 months later it will not even work on THIS new surge protector. Please help!! Model GM5607H Media Center
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 03-16-2007, 01:14 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Gateway doesn't work after Blackout
I bet if you take the memory out, wave it around like a 5 year old with a pixie stick for a few seconds, and put it back in it will POST and boot up.
I service a lot of Gateway computers on campus and I see this problem a lot. They use shit motherboards with faulty RAM slots that occasionally go haywire, and re-seating the memory tends to get it to work again. Give it a try.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 03-16-2007, 01:38 AM
Dyno247365's Avatar
You were right...sort of, I didn't touch the memory but I opened the case and looked inside, checked the fan. then closed it up and it works now, just like at Best Buy.
Old 03-16-2007, 08:49 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Just the time you took to check out the fan might have been enough to drain the capacitors and truly remove all power to the mother board. every PC should be turned off and unplugged (or turn off the AC switch on the power supply) for at least two hours once a week to fully power down the mother board and memory sticks. ALWAYS unplug the power and wait a couple of mins when removing or adding memory, power is still supplied to the mother board even when you shut down windows, there should be a
red LED on the mother board to tell you when the capacitors are depleted, but wait awhile after it goes out just to be safe. a quick cold start or power failure won't quite do it, just be sure your cmos battery is good or that you have a flash back up of your cmos settings.
There's been a lot of times peeps throw the PC in the back seat and drive it down for repair just to find nothing wrong. just needed time.
