Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-15-2007, 08:05 PM
daba daba is offline
1987 camaro won't start
I have a 1987 camaro that was running one day and then the next day it would not start. I think it might be the distributor cap,but i'm not sure. Is there any way to test the distributor cap? I can smell gas,but it will not start. What might i be able to do about this problem?
Old 03-15-2007, 08:12 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: 1987 camaro won't start
What kind of noise does it make? Battery good?
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 03-15-2007, 08:19 PM
When i turn the key to the on position i can hear the fuel pump and the battery is a brand new one. I have looked over many things and i don't see of any problems
Old 03-15-2007, 10:31 PM
goldz28's Avatar
goldz28 goldz28 is offline
Do a search on the forum for VATS or vehicle anti theft system. Could be that if your key has the lil chip in it.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 03-15-2007, 11:42 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
I don't think there was VATS in '87, could be wrong though. Does the engine crank? I doubt it would be the distributor cap unless you've been noticing a rough idle and rough running conditions lately. What EXACTLY happens when you turn the key, sounds and sights?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 03-16-2007, 01:11 AM
Morley Morley is offline
In 87 VATS was only in Vetts.
Old 03-16-2007, 01:13 AM
goldz28's Avatar
You learn somthing new every day.
Old 03-16-2007, 05:25 AM
When I got the car about a month ago, it was running rough. I would be able to start it, but it would stall out. I would be able to do that a few time, then it would run rough at first, then run a bit smoother. The last time it ran, it only ran for a few seconds, then stalled. It did this a couple times, then nothing. It hasn't run since. I put a code reader on and it comes out with no errors. When I try to start it, I can hear it cranking, but once in a great while it sounds like it tries to fire, but then just a cranking sound again. I can smell gas when I do this. The only lights I see are the normal lights that light up when you try to start the car, but those always lit anyway.
Old 03-16-2007, 09:29 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Have you done any retuine amint. since purchasing the car?
No need really for cap, just inspect for crack, carbon tracking, corrosion etc.
Then you need to verify if you have spark and what the condition is.
Old 03-16-2007, 01:54 PM
How would you check for spark in a car?
Old 03-16-2007, 08:12 PM
Pull off one of the wires where it goes onto the spark plug, put the metal part of the connector about half an inch from a ground (you may want to hold it with some pliers), and have someone crank the engine over. If you see it arch between the wire and ground you have spark on that cylinder, and probably the rest.
Old 03-17-2007, 01:13 PM
Where exactly should I place the wire on the engine? And what would I try if it doesn't have spark?
Old 03-17-2007, 03:30 PM
It seems like when I try to start it,it wants to start occasionally but then it just stops and does nothing. Should I try replacing the cap or just keep trying other things?
Old 03-18-2007, 08:08 AM
SG007's Avatar
Caps are pretty cheap, might as well try that first.
Old 03-18-2007, 08:48 PM
yeah I just bought a cap+rotor, I think it was under $20. Take yours off and look at the metal in it to see if they're corroded. Couldn't hurt to do the ignition coil at the same time, thats $21 new on eBay, never checked the stores.
You should put the wire near a ground (stut tower bolts, header, etc.) something metal and grounded.
How long has it been since you've changed your spark plugs?
