Old 03-15-2007, 05:41 PM
fred carl fred carl is offline
Where is drain plug?
Hi,
I have a 93 Voyger 3.3 and need to drain the coolant. I can't find
the drain!!!! Anyone know where the drain is located? I have a
blown head gasket and am going to try to fix with BAR'S LEAKS
Head Gasket Repair Kit.
Thanks
Fred
Old 03-15-2007, 05:55 PM
jsinton jsinton is offline
Re: Where is drain plug?
I can't find info on the drain plug, but normally I just remove the bottom radiator hose and do it that way, as a lot of cars don't have a drain plug.
Old 03-15-2007, 06:13 PM
Bear Bear is offline
On my '96 Caravan, 3.3 it is located a lower left (driver side) of the radiator. I do not recommend removing it as the rubber gasket tends to shred and then a new plug is in order. I would agree with removing the lower radiator hose and draining her that way.
