Old 03-15-2007, 03:34 PM
leftsetter leftsetter is offline
Angry Front wheel studs
How do you change the front wheel studs on a 95 LeSabre? TIA
Old 03-15-2007, 03:45 PM
maxwedge maxwedge is offline
A990 racer
Re: Front wheel studs
Check autozone.com/repairinfo for the procedure.
Old 03-15-2007, 04:22 PM
Scrapper Scrapper is offline
AF Premium User
when you knock them out with hammer, while turning the front until you see you got enough space to put new one in..then put 1or2 bigger nut's around them then start your new nut on it draw them up tight to pull stud threw, oh and little bit of packing grease or oil on new stud..good luck...
Old 03-15-2007, 04:26 PM
Front wheel studs
Thank you both for the quick replies, I will let you know how it turns out.
Old 03-15-2007, 04:37 PM
imidazol97 imidazol97 is offline
AF -Advisor
I did this on a 98. I used a 3 pound hammer, bigger than a carpenter's hammer. I used a capenter hammer on the back to absorb some of the impact on the hub. There is one spot near the top where there was room for the stud to come out toward the axle.
I used washers under the nut to pull the new stud in. I put the nut on upside down so the flat top of it was rubbing on the washers to pull the new stud in.
Old 03-15-2007, 08:18 PM
A990 racer
Careful whacking these studs out, this damage the bearing.
Old 03-18-2007, 10:54 AM
Thank you everyone for your help, I can now drive safer.
Old 03-19-2007, 04:01 PM
AF Premium User
Smile Re: Front wheel studs
no problem...keep driving safe...
