Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-15-2007, 11:28 AM
drmrjohn drmrjohn is offline
Electrical problems 93 transport.3.8 ltr
Hello, I was out canvassing for the Kidney Foundation when i noticed a burned wire smell inside the van(only thing running at the time was heater)-I then heard the heater fan was not running right(making a squeeking clicking noise) so I shut it down right away (it does have bad high speed relay just havn't had a chance to change yet) anyways-the smell went away and everything was good-I just stopped using the front heater fan, then I started to get an interferance noise out of the radio (high pitch whining/buzzing noise that matches revvs on the engine) and the ABS light stayed on-Then yesterday as I was driving the interferance noise became louder and started to make a buzz noise on and off -then the van started to buck a bit but I drove home and put it in park-then was trying to rev it up but it was acting sluggish and the tach indicator needle was going the wrong way and pinning down at the bottom-I shut it off right away and left it-I came back after awhile (pulled the heater fuse) and it started right up and ran ok(but the heater could still be turned on with fuse out) I then turned it off and it wouldnt start again as the battery was not strong enough-any Ideas? I can put a multi meter inbetween the batt post and connector and pull fuses to see what circuit may be bad-but any other suggestions? This van was working so very good and I hate to scrap it over this-any way to check the charging system to see if it is working right now? Thanks guys any assistance would be awesome!
Old 03-15-2007, 09:07 PM
LMP's Avatar
LMP LMP is offline
Re: Electrical problems 93 transport.3.8 ltr
First suspicion is alternator failure, a common problem. If you can start it again, check voltage : it should read around 14.2 or slightly more when cold. Most symptoms you decribe are relevant of low system voltage. I think you have at least one open diode in the alternator. IN any case, an easy check before looking for more complicated...there is ample time left to come to that....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
