Old 03-15-2007, 09:21 AM
parmotinc parmotinc is offline
93 Blazer turn signal problems. Help.
93 Blazer 4x4. Turn signals are not working. Hazard lights do work. Turn signal switch is making good correct sounds and feels normal. Wanted to swap out the hazard light relay with turn signal relay, but unsure if I got the right one. Behind the hood pull is the hazard light relay and horn relay. Is the turn signal switch relay on the fuse panel? Thanks in advance.
Old 03-16-2007, 07:59 AM
JaVeRo JaVeRo is offline
Re: 93 Blazer turn signal problems. Help.
Check all of your bulbs first to be sure you don't have a bulb burned out. Do your brake lights work?
It has been a few years since I sold my 91 but I am thinking that the flasher (not the relay) for the turn signal and emergency flasher are interchangable. The emergency flasher will handle more amps and I would buy an extra emergency flasher to replace the turn signal flasher so it would flash correctly with a trailer connected.
I think both are on the fuse block beneath the dash, they are round and have two prongs at a 90 degree angle. The turn signal flasher may be plastic.
I don't know if this truck even had a relay for the flashers. I think it was just fused.
All of this is from memory and I don't remember what I did with my cell phone last night so take it for what it's worth.
James
