Old 03-15-2007, 09:03 AM
gregs3000gt gregs3000gt is offline
Cool 92 3000gt vr4 awd rear steer
help rear steer goes goofy on hwy can i disconect it
Old 03-15-2007, 09:33 AM
Igovert500's Avatar
blue + red light magnet
Re: 92 3000gt vr4 awd rear steer
What do you mean it goes goofy?
It should only turn a degree or 2, nothing huge. If it's affecting your driving, I would guess it's something more than the AWS. Like screwed up suspension components, tie rods, etc.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-15-2007, 11:29 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Igovert is right. the AWS (all wheel steering) in the rear is activated above 31mph and is only noticed really at highway speeds upon changing lanes. instead or turning the car into the lane then having to steer it back straight, the rear wheels turn up to 1.5 degree IN PHASE (so same direction as front wheels) and you sort of glide or slide into the next lane.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
