Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-15-2007, 08:03 AM
jarobbins jarobbins is offline
1993 Battery Problem
I have a 1993 Thunderbird 3.8 liter 6 cylinder. I do not drive the car every day anymore, but last weekend I went to start it and the battery was dead. I took the battery to Auto Zone and they said it was dead. I bought a new one and the car started just fine. That was Sunday. I went to move my car out of the garage yesterday and it the battery was completely dead. I hooked the battery to a charger overnight. Is there something wrong with the car itself that could be draining the battery completely in 3 days. No lights or accessories were left on. Thanks
Old 03-15-2007, 10:57 PM
overl0rd overl0rd is offline
Re: 1993 Battery Problem
Has it been cold where you live? If not, you have a parasitic load. Make sure nothing at all is left on, and hook a test light between the negative battery cable and terminal. (Unhook the terminal first.) Then, start pulling fuses untill the test light either goes out or dims considerably.
Old 03-16-2007, 12:53 AM
SwiftThunder's Avatar
SwiftThunder SwiftThunder is offline
My aunt has the same problem on her 95 bird, ill have to mention that test to her.. TY! and reguarding your 93 goodluck! That is a difficult problem it seems.
Old 03-16-2007, 07:41 AM
Thanks, I will give that a try.
Old 03-18-2007, 11:15 AM
97Bird's Avatar
97Bird 97Bird is offline
First things to check are the courtesy lights. Be sure they are not staying on. These include interior lights, glove box, hood and trunk lights.
The Original 97Bird
Old 03-18-2007, 01:52 PM
Hey can the ignition switch cause this too, in my aunts 95 her car always dings when the door is open whether there is a key in the ignition or not, and you can spin the key sleve around and around.
Old 03-19-2007, 03:40 PM
Mama's T-Bird Mama's T-Bird is offline
Send a message via Yahoo to Mama's T-Bird
Same thing happened to my wife's 91-Bird. Took it to the mechanic cause I figured it had a short somewhere. It was the alternator. Mechanic said sometimes when alternator goes bad it will keep draining current even if the car is shut off.
