Old 03-14-2007, 05:27 PM
Fred Flintstone Fred Flintstone is offline
95 astro blower fuse blows
Hi, I have a 95 Astro that started blowing the fuse to the blower motor. I replaced the resistor pack and the blower works fine with heater or vent but when ac is turned on the fuse blows. Any suggestions on where I should begin?
Thanks in advance.
Old 03-14-2007, 05:44 PM
old_master's Avatar
Advisor/Moderator
Re: 95 astro blower fuse blows
There is a short in the A/C clutch circuit. A fairly common problem, and the first thing you can try, is disconnect the compressor clutch field wire at the top front of the compressor. You can access the connector by opening the hood, nothing needs to be removed. Just unplug the two terminal connector. If the fuse no longer blows, the field will need replacement. Post back your results.
