Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 03-14-2007, 05:02 PM
combatjumpmaster combatjumpmaster is offline
94 Beretta with shift problems HELP
I've got a 94 Beretta w/4 sp transaxle and 3.1 V6. It seems the shift cable from the shifter to the shift shaft/neutral safety switch will not take an adjustment. Nothing unusual has happened, worked fairly well prior to this, except difficulty getting it into park (but at least I could start it in neutral and it drove fine in all gears. Could it be the shift cable? It's trying to move the shift arm, and occasionally it gets into reverse but not back out. I haven't found an aftermarket cable, and I fear the shift problem may be inside the transaxle body. Any advice??? Thanks.
Old 03-15-2007, 09:38 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 94 Beretta with shift problems HELP
Try disconnecting the cable and move the lever by hand from under the hood. If it moves freely, the calbe is probably internally frayed and needs replacement. If it still binds by hand, tehn it may be an internal trans issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-16-2007, 03:50 PM
Thanks - it can be shifted by hand, so it sounds like the cable itself. But no one carries it, even GM direct. Off to the "junk" yard I guess.
