Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-14-2007, 05:00 PM
higputz higputz is offline
oil warning light
I have a 1997 sunfire 2.2. After the car warms up and is sitting in idle my oil light comes on when you acclelerate(or rev the engine) it goes off. I noticed that any time it goes uneder 1000 rpms is when the light comes on. I checked my oil and it is full. I have done an oil change on it and still no help. any suggestions on what it could be...
Old 03-14-2007, 05:20 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: oil warning light
Check the oil pressure sending unit should be located above the oil filter. Change it with a new one to see if you have a problem or try a mechanical guage. It is possible that the oil pump is going bad but doubtful.
Old 03-23-2009, 09:55 AM
metal4427 metal4427 is offline
Send a message via AIM to metal4427
I have the same problem...I replaced the oil pressure sending unit....The light still went on under 1,000 rpms.
So i installed a oil pressure gauge on my dash...and sure enough i've noticed oil pressure going down to zero.
So i did the next thing of installing a new oil pump....
Thinking my problems will be solved....
The oil pressure still goes down to 0. So now i have no idea what is going on...
