Old 03-14-2007, 02:51 PM
jtc001 jtc001 is offline
Seatbelt retractor problem
Lately, the driver's side seatbelt is not retracting. If I assist it, it will go in, it just does not have enough pull to retract by itself. This is a problem as I have closed the door on the seatbelt several times now.
I have an 01 extended cab with the seatbelt retractor in the driver's seat.
Has anyone else had this problem and is the cure anything except a new retractor?
Thank you.
Old 03-14-2007, 06:01 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Re: Seatbelt retractor problem
i have not had this problem but saw some posts on here once and they said it was cheaper to replace the seat than to fix the seatbelt.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 03-15-2007, 12:59 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Yeah, I do not think this is a common problem, unfortunetly.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 03-15-2007, 07:13 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
For some reason I want to say this was a recall for the early model nbs.
It may not be though.
*Under Construction - New sig to debut*
Old 03-17-2007, 01:05 PM
RWC1 RWC1 is offline
I got the same problem. Eccept mine quit retracting alltogether. Is there a recall. Another problem I have, is my 4 wheel drive will not go in to 4 wheel drive. Some say it's the push button part of it. I use to have a S-10 Blazer 4x4 and it did the same thing, wouldn't go in to 4 wheel drive. It was also the push button 4x4. On that one, it was the box behind the ashtray. I finally took the box out, and put it in the glove box, where it was easy to get to, and when I went in at night, I would unplug the box and bring it inside, out of the cold, and plug it back in, in the morning. And it would work. I don't know if it was a reset feature, or bringing it in from the cold. But it was better than paying $500.00 bucks for a small box. Which may or may not have been the problem. Between the seat belt and the push button 4x4, the rock is getting to be a pebble.
