Old 03-14-2007, 12:11 PM
PA93 PA93 is offline
ABS ! and traction off stay on
Hello!
I've got the problem with my '93 PA - ABS and 'traction off' lamps stay on after I start the engine - at the beginning they went off after some distance but only if I turned off the engine and started it again now they stay on all the time. Any idea?
Old 03-14-2007, 12:48 PM
maxwedge maxwedge is offline
A990 racer
Re: ABS ! and traction off stay on
You need to scan this with an abs function scanner for codes, most likely a wheel speed sensor is the culprit.
Old 03-14-2007, 12:53 PM
How can I do that?
Old 03-18-2007, 04:39 AM
How can I scan ABS system?
Old 03-18-2007, 08:10 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: ABS ! and traction off stay on
The answer to your question was posted above. You may need to take it to a shop & have it scanned to get the codes. Midas, Just Brakes and some other brake shops, keep an ABS scanner on site.
