Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-14-2007, 08:06 AM
maximum95 maximum95 is offline
motor
Does anyone know if I can put a 2.0 motor from a 96 talon in a 93 talon ? I mean will bolt right up, I have a 5 spd
Old 03-14-2007, 09:01 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: motor
Only if it's a 4g63. If its the 420a non turbo then no. Well you can, but lots of custom work. We need more info though to help you farther. What model and trim... gsx, gs, esi, tsi? The 420a and 4g63 are both 2.0L.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-14-2007, 02:37 PM
Re: motor
I have a 93 Eagle Talon es non turbo, do you know what motors would be an easy fit ?
Old 03-14-2007, 03:00 PM
david-b's Avatar
Dave is THAT guy
Re: motor
As long as its the 4g63 swap is fine. That all though.
75 Monte Carlo
Old 03-14-2007, 03:05 PM
Re: motor
this may sound stupid, but How do I find out if it's a 4g63? is there some place on the motor?
Old 03-14-2007, 03:09 PM
david-b's Avatar
Dave is THAT guy
Re: motor
It's a 4g63 non turbo. A direct swap is possible. However, there may be some problems with electrical, ECU, and connections. Someone else will have to verify the N/T thing into a turbo model.
Basically, you would need to take the 4g63 TURBO model from the 96 and drop it into the NonTurbo car. There may be some problems with that. Anyone else help here?
75 Monte Carlo
Old 03-14-2007, 07:12 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: motor
The best motor to replace the one in your car would be the same thing. Just get another 4G63 non turbo engine and put it in there. Any type of swap would be quite a bit of a pain the ass.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 03-15-2007, 08:05 AM
Re: motor
So if the motor out of the 96, is a 4g63 then it should be an easy replacement ?
Old 03-15-2007, 03:54 PM
NOFX0617's Avatar
Re: motor
No....they only made a turbo version of the 4G63 in 96. That swap would be very hard and not really the best idea.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 04-26-2007, 08:31 AM
Re: motor
ok thanks everyone !
