Old 10-08-2002, 01:12 AM
mengy mengy is offline
Wheel question
My front tires... go blad on the inside of the tires (not the outside... the side you can see but other side of the tire..).... is this because of alignment?
Old 10-08-2002, 01:14 AM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
That problem would be due to Camber. Sounds like you need a camber kit.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 10-08-2002, 01:41 AM
chamber? whats that and where could I get one and for how much?
thanks what if i plan on lowering my car in the future?
Old 10-08-2002, 05:45 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
see how mu wheels are tilted? its because i lowered my car, this will happen to my soon... I have to get a camber kit ASAP!!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-08-2002, 07:43 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: Wheel question
Originally posted by mengy
My front tires... go bald on the inside of the tires (not the outside... the side you can see but other side of the tire..).... is this because of alignment?
If your car is currently NOT lowered, it is probably due to alignment. If it is lowered, then it is usually a camber issue. However, after you lower your car, and install the camber kit, you should also get it aligned
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 10-08-2002, 10:05 AM
Re: Re: Wheel question
Thanks, I appreciate the help btw is the a lip on the front bumper of your car? How much did you lower it? it looks nice...
Old 10-08-2002, 12:04 PM
jc836 jc836 is offline
Again-If you lower the car 1" the Camber will go negative by ~0.75 degrees (The top tilts in). Let's say you drop like mine about 2" that should be about -1.5 degrees and if the spec for the car is a maximum of -1 degree you are now out by 0.5. Hello Camber kits front and rear. What you need is an alignment anyway-get the printout after they set the Toe-in, which BTW will destroy tires real fast too. With the printout you can check both Ingalls (www.ingallseng.com)and Specialty Products (www.specprod.com) and find the kits you need. As an example: Ingalls has their #3571 and 3573 for the front of a CRX and several others for the rear, including a control arm replacement. Specialty also has similar parts. If you happen to plan on racing in Improved Touring then the options are limited in the rear to using shims-which actually is a good thing cost wise.
Hope this gets you on the right track.
