Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-14-2007, 12:53 AM
crxrcrxcrx crxrcrxcrx is offline
Help 95 eclipse head on a 97 gst
so i have a 95 turbo head on my gf's 97 gst does anyone know how to use the cam sensor considering there isnt one on the pass side of the head only on the cam gear if you can help please let me know
is there anything i can do
the car is completely put back together and it wont start theres no spark
Old 03-14-2007, 01:17 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Help 95 eclipse head on a 97 gst
Im not 100% on this but I think you would need to use the cam sensor from the 97 CAS on that head and not the one from the 95 and that also means you might have to get the intake cam drilled and tapped. But if you are looking for where the CAS is for the 95 it is over either mounted on the crankshaft itself or its right next to it from what I remember.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
