Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-14-2007, 12:28 AM
namster namster is offline
Unhappy compression readings
hello my 1987 pickup 22r is running rough, seems like cyl. 2 is not working.
my compression readings at cyl. 2 is 150 and the rest is at 180 psi.
no noticable changes when i pulled the plug wires from cyl. 2, not like the others. truck was overheated, new headgasket was put in.
put small amout of oil in cyl. 2 and recheck compression, came up to 180psi.
truck still runs rough. any ideas?
Old 03-15-2007, 07:38 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: compression readings
How does the plug look ?
Are you sure you are getting spark to cyl 2 ?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 03-17-2007, 12:40 AM
yes i am getting spark, i did a leak down test today, air is coming from my intake and a little from exhaust, i loosen up the valves, it has gotten a little bit better, but not as good. i think i have a crack head, probably near the valve seat area?
