Old 03-13-2007, 10:48 PM
unknown_sender12 unknown_sender12 is offline
7.3L smokey start ups
I have a 2002 F250 with a 7.3l power stroke turbo diesel with 130,000km on it. Lately we have been having mornings that are 37F and it smokes pretty bad for the first 4 minutes, yes i let the glow plugs run until the light shuts off. When we had temperatures around this last fall it wasnt this bad, i havent made any mods over the winter, and i did run fuel conditioner every few tanks during the winter. Any comments?
Old 03-14-2007, 07:49 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Re: 7.3L smokey start ups
If you have one use the block heater. My truck does the same thing there is nothing wrong it's just cold.
Old 04-08-2007, 07:13 AM
rdhzrd rdhzrd is offline
Most likely your glow plug controller is defective. Everything will appear to work but the solinoid is not switching. Check it out because its not that common for glow plugs to fail in the powerstrokes however they do fail sometime. Check all of them through the valve cover plug in. Hook up your test light in reverse and touch each large pins ( 8 ) on the engine side with the key off,you are just checking for a good circuit,if your light comes on that plug is good etc. The other little pins in the valve cover gasket are for the injectors. If you have a bad glow plug on each side ,change them all because its a lot of work to get to them.
