Old 03-13-2007, 09:01 PM
jwokmuba2 jwokmuba2 is offline
Exclamation oil pressure sensor problems
1988 cheny 2500 5.7 liter 350
in the morning when i first start the truck the oil pressure will read about 20 but when the truck warms up it drops all the way down to 0 and the engine service light come on, the gauge doesnt drop all of the sudden its slowly drops as the engine warms, untill it hits 0
Old 03-13-2007, 09:04 PM
2000CAYukon 2000CAYukon is offline
Re: oil pressure sensor problems
It would be best to use a mechanical gauge to verify the correct oil pressure. The oil pressure sender does go bad but a mechanical gauge will tell the real pressure.
//2000CAYukon
Old 03-14-2007, 07:17 AM
67malibu 67malibu is offline
This is a common issue on these trucks. My '88 350 did this a few years back. While a mechanical unit is definitely better, the electronic sending unit is easy and quick to change.
Old 03-14-2007, 09:40 AM
daman daman is offline
I agree,, verify with a mechanical gauge.....
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 03-15-2007, 05:55 PM
thanks for advice, i bought a manual gage and the pressure reads about 30 all the time, but the gage in the cluster still has the same issue, it still reads even though the sensore it is unpluged, any suggestions,
Old 03-16-2007, 07:55 AM
waterboy1381 waterboy1381 is offline
Send a message via AIM to waterboy1381 Send a message via Yahoo to waterboy1381
No suggestions for the problem with the gauge... but does your trucks oil need to be changed? I know on my 1995 C-1500 with a 305, everytime the oil is close to needing replacement, the pressure gauge goes nuts, start out at 60, down to 40 when i step on it when its cold. When its warmed up, it will run 35 and drop down to about 5 when i step on it.
When i have fresh oil though it stays constant 60-70
Old 03-16-2007, 02:31 PM
no i just changed it last month
