Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-13-2007, 09:02 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Well, the datalogger doesn't even work.
My 90 Galant isn't getting an injector pulse. there's fuel in the rail, the starters going, i've got spark, there's just nothing getting into the cylinder.
but that's not what i'm trying to fix.
I just bought a datalogger a palm III (mmcd), came with the software, cable, and hotsync cradle.
background: Car is a 1990 Galant AWD, with VR4 conversion, ecu, 4g63t, trans, wiring harness, teh works.
I plug the datalogger into the port located below the dash on the 90 Galant N/T. doesn't do anything. I try starting the car, still no readings, i fiddle with some of the check boxes in the program. still nothing. My question is mostly for those that have done the n/t conversion. How did you get your datalogger to work?
is there a difference b/t the non-turbo cars and the turbo cars by means of datalogging?
is there a difference b/t the 90 and 91 that won't let me datalog this?
or worse, am i just entirely incompetent with using the datalogger?
i guess i've got more troubles than the damn things worth b/c of all the conversion stuff i've had to do, but almost all of it should be bolt-on affair.
any help at all is appreciated.
Don't act like you don't love it.
503/2000
Old 03-15-2007, 12:34 AM
Sleepr awd's Avatar
Re: Well, the datalogger doesn't even work.
anyone?
503/2000
Old 03-15-2007, 01:49 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Well... I put a lot of thought into this last night but couldn't think of anything really that would help. There should be no difference in the years for datalogging purposes, but the OBD ports could be different between turbo and non... Do you have the turbo one laying around anywhere?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 03-15-2007, 09:14 PM
Sleepr awd's Avatar
i have the whole turbo interior harness. i just was hoping maybe someone with the n/t swap could help before i tore the dash apart again.
503/2000
Old 03-16-2007, 02:50 AM
Ahh... Hopefully someone will know... I know how bad it sucks to pull a dash out. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 03-19-2007, 09:11 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Does MMCD work with OBD-I? Also, what does your datalogger cable look like? I know for 1g's there is an additional wire that need to be plugged in somewhere to provide the cable with power. I know that's not the most technical way to put it, but I'm not too versed on the 1g's.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-19-2007, 11:30 AM
Ohhh Ya know what, your right... The cable needs to run another wire into the fusebox to any random fuse. I totally forgot about that. We had to do that in my one buddys old 1g... Did you do that too?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
