Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-13-2007, 07:01 PM
93MercMarquis 93MercMarquis is offline
Brake Problems
Yeah this car gave me no problems all the way too 100 thousand miles now it's one problem after another I just posted a thread about flickering headlights which is now fixed now to the problem on hand so I'm driving down the roading and the car starts making this pulsating feeling I ignore it so I pull up to a light and I smell this real bad burning smell I look and see smoke comming from the wheels as I drive futher down road the braking of the car gets worse and worse so I pull into my drive way I inspect the back brakes they are nice and cool I inspect the front brakes the rotors are a bright red color now only thing I could think of is the ABS is locking and unlocking the brakes as I drive hence the pulsating feeling if somebody could give me some help I will be greatful
Old 03-13-2007, 07:08 PM
reekor reekor is offline
Re: Brake Problems
If the abs was triggering you would hear it. Did you have the front brakes replaced lately?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 03-13-2007, 07:34 PM
Re: Brake Problems
Yes all 4 Disc Brakes were replaced not to long ago The brakes have only 2k on them and rotors and brake lines all were replaced not to long ago and oh yeah you could hear it and it was a pulsating feelling so I'm thinking ABS
Old 03-13-2007, 09:02 PM
Re: Brake Problems
Are the front and rear tires the same size and was the abs unit bleed when the lines were replaced?
Old 03-13-2007, 10:09 PM
Re: Brake Problems
Yes Front and Back are the same Size I'm guessing they did bleed the lines took it to a Ford Dealership to have the work done Altho maybe I should try re bleeding do you happen to know where the fuse is for the ABS I'll try unplugin it and if it stops then I know for sure it's the ABS
Old 03-14-2007, 12:26 AM
Re: Brake Problems
Drivers side inner fender
Old 03-14-2007, 08:47 AM
Re: Brake Problems
well thanks
